SPOTM September 2022, any Pilatus aircraft including gliders
this forum contains the entries and votes for the 2022 competitions
Locked
Post by andygolfer » Thu Sep 15, 2022 9:24 am
This is the SPOTM (Special Photo Of The Month) competition for September 2022 and the subject is any Pilatus aircraft including gliders
The subject of your entry should be a photo of one or more civilian registered Pilatus built aircraft. It can be active, retired, preserved or just abandoned. If it is a former military aircraft it must have a civilian registration at the time the photo was taken.
3. The image can be photo-shopped to some extent, levels changes, cropping, sharpening etc. are all acceptable. The photograph must retain it’s initial subject though, don’t make it something it’s not. HDR images are not acceptable. If you are unsure, please PM a moderator.
4. The competition will remain open until 23.59 (UK time) on the 7th October 2022 - please note the extended closing date to enable anyone with a last minute photo plenty of time to prepare their entry.
6. 'Rule 6...' There's no rule 6, Bruce'
8. All images must be posted in line with the usual CA posting rules (size etc.), please read them if you're not sure how to post.
10. Please also embed the images and not links to images, if you're not sure how to do it then shout up and someone will sort it out. It is permissible to change your entry before the closing date.
11. Do not comment on other member's photos.
12. A brief description of where and when the image was taken would be nice too.
If you have any questions please PM me
Re: SPOTM September 2022, any Pilatus aircraft including gliders
Post by acw367 » Thu Sep 15, 2022 11:39 pm
D-FGMT Pilatus PC-9B EIS Aircraft RIAT Fairford Departures day Monday 19 July 2004
ImageD-FGMT RIAT Fairford Mon 19 July 2004 by ACW367, on Flickr
BringBackEGDG
Post by BringBackEGDG » Sat Sep 17, 2022 11:31 pm
Pilatus P2-05 G-PTWO/U-110 Swiss Air Force markings at Badminton fly-in 21st April 1991.
Image1991-04-21-009FN G-PTWO by Stephen Rendle, on Flickr
Mike s
Post by Mike s » Mon Sep 19, 2022 11:35 pm
PC-6 Pilatus Porter
ImageD-FIBE PIK 11.5.2021 by Mike stanners, on Flickr
niallsaviation
Post by niallsaviation » Wed Sep 28, 2022 10:56 am
ImageEI-IAN by Niall Moran, on Flickr
EI-IAN PC-6 Turbo Porter - Seen at The Birr Airshow 7th August 2017
Reg cancelled 28-05-201 & now registered D-FANO
Post by andygolfer » Thu Sep 29, 2022 4:03 pm
this is mine from Little Gransden in Auguat 2013, a PC-12, M-JJTL taxiing in on the day of the annual airshow
ImageM-JJTL Pilatus PC-12 Lt Gransden 25-08-20138634 by Andrew Goldsmith, on Flickr
good luck everybody
Post by Nighthawke » Thu Sep 29, 2022 4:34 pm
Pilatus PC-6 F-GOAG taken at Saumur 16th August 2015.
ImageF-GOAG_2 edit
Gloria Finis
Post by Gloria Finis » Mon Oct 03, 2022 7:55 pm
The 5th and oldest operational PC-6, having been built in 1959.
ImagePilatus PC-6 Turbo Porter, F-GODZ, Fly High Icarius @ Strathallan, 08 August 2012 by Phillip Hapka, on Flickr
Post by LondonEye » Wed Oct 05, 2022 5:52 pm
Here is a Pilatus P3 seen at Fairford 2011.
ImagePC-3 HB-RBP 3 Fairford
Locked
Return to “2022 Photo Competitions”
