Glasgow on A Misty 08/02/2017
rab5869
Post by rab5869 » Wed Feb 08, 2017 7:14 pm
Been having problems with either my lens or my camera body with either front or rear of aircraft being blurry really cant figure it so hoping i can get some feedback on these images that i took today
ImageG-WMRN by LoanWolf Aviation, on Flickr
ImageG-LGNN by LoanWolf Aviation, on Flickr
ImageG-EZFE by LoanWolf Aviation, on Flickr
ImageF-HBXF by LoanWolf Aviation, on Flickr
ImageEI-FAT by LoanWolf Aviation, on Flickr
ImageD-AEWI by LoanWolf Aviation, on Flickr
ImageThomas Cook by LoanWolf Aviation, on Flickr
Many Thanks For Viewing
Rab
Re: Glasgow on A Misty 08/02/2017
Post by Martin » Wed Feb 08, 2017 9:04 pm
I do like the landing TBM, they seem to be becoming as popular as the PC12 in the UK
scarba
Post by scarba » Wed Feb 08, 2017 9:56 pm
It sounds like you are having Depth of Field problems.
If you are using a zoom lens at its maximum setting the depth of field is short. If you use a larger aperture ie f8 or f11 this should help.
There are several articles about this online which explain the technicalities much better than I can !
Caravelle 10R
Post by Caravelle 10R » Wed Feb 08, 2017 10:40 pm
Keith the photos posted seem okay so assume these are not included images you are concerned about? Depth of field is a potential but you seem to be using adequate f stops to avoid anything too significant even at the long end of the lens. Using selective auto focus points could effectively put one portion of the aircraft in focus with the resulting drop off in focus across the body. An uneven panning could result in a distorton. That said looking at your Flickr you have some really nice shots and seem really competent in producing good shots. I would just put the lens and camera through their paces. Testing static and moving shots trying out the range of f stops and individual focus points. It may be the only way to rule out any calibration/focus error that can potentially creep into a lens.
rab5869
Post by rab5869 » Wed Feb 08, 2017 10:40 pm
Many thanks for the comments much appreciated i will try thebsetting you suggested scarba i am using
Canon 700d body and canon 100-400mm l seris is lens.
I will also try your suggestions too caravelle 10R
Many thanks again guys
rab5869
Post by rab5869 » Thu Feb 09, 2017 12:49 pm
Well tried everything that was said and still the same so called company that i bought it from and they are picking it up on mon and sending another one out to me they said it sounds like misalignment of the lens so just wait and see how this other one is.
Users browsing this forum: Google [Bot] and 36 guests
