SPOTM February 2016 - Radial engines
This is the SPOTM (Special Photo Of The Month) competition for February 2016 and the subject is 'Radial engines',
The subject of your entry should be one or more civilian registered aircraft powered by radial engines. Aircraft which at some time have previously carried a military registration but subsequently transferred to the civil register are acceptable.
3. The image can be photo-shopped to some extent, levels changes, cropping, sharpening etc. are all acceptable. The photograph must retain it’s initial subject though, don’t make it something it’s not, (cutting and pasting the moon into the shot, for example !). HDR images are not acceptable. If you are unsure, please PM a moderator.
4. The competition will remain open until 23.59 (UK time) on the 1st March 2016, to enable anyone with a last minute entry some breathing space.
6. The decision of the moderating team is final.
7. All images must be posted in line with the usual CA posting rules (size etc.), please read them if you're not sure how to post.
8. The rules may be subject to change, and these will be posted on this thread.
9. Please also embed the images and not links to images, if you're not sure how to do it then shout up and someone will sort it out. It is permissible to change your entry before the closing date.
10. Do not comment on other member's photos.
11. A brief description of where and when the image was taken would be nice too.
If you have any questions please PM me
Good luck everyone.
Andrew
Good luck everyone.
Andrew
Re: SPOTM February 2016 - Radial engines
and I'll kick it off this month, from Little Gransden airshow 2012 WACO UPF7 G-UPFS about to touch down....
2143 WACO UPF7 by Andrew Goldsmith, on Flickr
good luck everybody and lets see lots of entries again this month please
Bristol Blenheim now registered as G-BPIV. This was taken at RAF Fairford in July 2015.
20150718-DF1A0683.jpg by Mike Grundy, on Flickr
Consolidated Catalina, G-PBYA of Plane Sailing. Seen here displaying at Shuttleworth in 2015.
Consolidated PBY Catalina by Dan Elms, on Flickr
Putting it's homebuilt Webster Whirlwind radial engine through its paces. G-BMOO Clutton FRED Series 2 Aeroexpo Wycombe Air Park 13 June 2009.
G-BMOO Wycombe Air Park 13 June 2009 by ACW367, on Flickr
N4712V Boeing E75 Stearman .... Photo taken at Hardwick some time ago ??
Yak 50 and 52 of the Yakovlev Aerobatic Display Team at the Henstridge August 2014 Fly-in
- BringBackEGDG
Royal Navy Historic Flight Hawker Sea Fury T20 G-RNHF at Flying Legends 2012
2012-06-30-059FD G-RNHF by Stephen Rendle, on Flickr
- Paultojo
Dakota Norway Foundation's C-53D LN-WND at Flying Legends 2011:
Douglas C-53D Skytrooper, Dakota Norway Foundation by Nick Challoner, on Flickr
Charlies Heavy. Gruman TM3R Avenger HB-RDG
Engine run-up on an early morning. Picture taken at the airfield of Schaffen ( Diest )
My Flickr pic's:
https://www.flickr.com/photos/nqypics/
Newquay Airport Movement's Blog:
https://newquaymovements.blogspot.com/
Mark
Mark
- Nighthawke
an antonov AN2 taken back in 2010 at the Battle of Britain Airshow at Kemble
