It sometimes pays to think outside the box, the irony of it was when I was scoffed at by someone sporting a large lens "Do you not have a bigger lens?" I showed them the 500mm and said don't need it!
I saved the more exciting stuff for the other camera :pScunnycelt88 wrote:I like the photo alot a good take on Edinburgh.
Only shame for me is the Brussels Airlines being the exotic plane of the group, hopefully this will improve overtime. GOOD WORK!!
Thanks Dan, I set the camera atop a tripod with a wide angle lens (18mm) & made sure it would not move during the image capture (30 mins in my case) I then took several photos of each aircraft as they passed the frame. Once the easy bit was out the way it was back home to shove them together using blood, sweat & photoshop. Many layers later and some fine polishing the above image is what you get.DanBeeden wrote:This is very impressive - how did you do it?
Users browsing this forum: No registered users and 110 guests
